Subwoofer not working
Car  clio 1.2 dynamique
i unplugged it to clean out my boot, and reconnected it and it now wont turn on....., the fuse hasnt gone on it the power light just isnt coming on it is all connected up any ideas?
We can't see if it's connected up correctly. Make sure you've put the wires where they are meant to go and all are making good connections.
There should be at least two fuses, one(or more) on your amp and one in the power line between battery and amp. Check ALL fuses, the power cable may have made contact with something whilst the amp was out and blown the in-line fuse.
See this as an opportunity. Throw it in wheelie bin, and replace with some quality components!!
Not helpful I know, but.....you know it makes sense : )
Check you're earth is still connected?
It's hard without seeing it tbh, just make sure all the connections are tight and in the right terminal
it is indeed an active sub, and ill check the fuse on the power cable later, i forgot about that:/ my badd sorry ,thankss!
