Does it use a separate fuse? If it does, check it has not blown.
Is there a second fuse box, perhaps within the engine bay?Hi. Thank you for the tip!
I guess there is a fuse, but I can not find it. In my user user-manual there is no indication about the sunroof fuse. It is not, for sure, inside the internal fuse box of the car.
I agree. I'll try to locate it.Is there a second fuse box, perhaps within the engine bay?
If the sunroof does not even make a noise now, it would suggest it is not getting power?!
HI, this fuse box does not exist on my car. Thank you!Don't know if this helps, looks like there is a fuse box next to the steering wheel. https://fusesdiagram.com/renault/fuses-and-relay-renault-clio-3.html
F3 - 15A Fuse
