Sunroof leaking, not seals though
  Mk3 dci
Hi guys,
Title says it all really, I've got a mk2 ph1 and the sunroof seems to be leaking from the mechanism that opens the sunroof. It's not a really bad leak but I noticed it after driving in the rain. Any help would be much appreciated cheers :)
LB197
if you take the arch liners out slightly under the front wheels towards the front of the door, theres a tutorial on here somewhere, you'll find like 15 years of shite in the sills :), this blocks the drains in the sunroof and makes them leak sometimes, worth a try :)
GrahamS
  335d, GT4
The drain for the sunroof is in the skuttle so the above is unlikely to cause a problem.
Bet it's still the seals though
  Mk3 dci
Thanks for the help guys, it seemed to be leaking through the opening mechanism so I tightened the two screws (they're t20 I think) and that appears to of fixed it. Not had much rain since so we'll see soon!
