Suspension...... Eibach Pro's?
  • Thread starter Thread starter 172Petey
  • Start date Start date
1
172Petey
Want a good upgrade for my cup, was looking at the Eibach Pro springs, but there just springs.
Whats a good upgrade, for a better rebound rate and a stiffer spring?
Not coil overs as I dont need the adjustment, or can be bothered with it!
you'd probably find a set of lowering springs on std shocks would greatly improve your ride mate.
Just got a set of sachs -35mm put on mine, and they are superb! Sit really well, reduced roll massively, and hasn't compromised the ride at all
shocks arn't as much as you might think standard ones are only £50 a corner
OK well thats £200 on top of what you already shell out for some springs!!
Thats not the proplem though. I want really good dampers, that will be better than the o.e ones and will suit the pro line's (or any other recomended springs) better!
I believe Eibach dampers do not fit RS
there is not one decent spring/damper combo on the market (besides coilovers)
you might try a set of springs(pro's, sportlines or H&R's) with Koni or Bilstein Sport/Sprint dampers
Eibach Pro's go well with OE dampers
U cant get koni shocks without the springs though? and if u can it would probably cost nearly as much.
Probably just worth saving up around £450 for a set of FK's/Gaz etc coilovers
