suspension problem
  clio sport 182 cup
hi,i own a clio 182 cup, which i recently lowered on gaz coilover's.i've had the car lowered 45mm on the front and 50mm at the back,the problem is when driving the car is fine.but when setting off with full lock it seem's as tho the tyre's are trying to dig in to the floor.it's had steering geo done and new ball joint's the lot,wheels dnt catch..will it need camber correction bolt's or is something else wrong?all advice will be appreciated.cheers.
Gaz_
  Extreme mode
Thats your problem, right there. ;)
All 182's on full lock tend to 'chew' as they're over tyred. I wouldnt worry
J
jonnytheboy
Mine does it too!!! Dont worry apply more power with the traction control off. ;)
  Golf GTD Mk7
its normal mate. does this on the standard suspension. it's the tyres struggling for grip and slipping
