Suspension replacement - setting up?
  tiTTy & SV650
I have finally got my hands on some Koni adjustables, will be fitted to my ph2 172 along with some Eibach Sportlines.
Question is, is any sort of setup required? I hear people talk of alignment and corner weighting etc with 'coilovers'
Is this equally applicable when replacing shocks and coils?
Ali
  V6, Trackhawk, GTS
Nope...because you can't adjust the ride height!
Fire them on, make sure the toe's ok...If you can adjust the camber get some lasers on it.
take it you won that set on fleabay...
  tiTTy & SV650
Indeed, cool so it's purely to make sure an even ride height and balance then?
Don't have camber adjustement and I won't be adding camber bolts.
£275 for koni adjustables with apex springs, 1 month old.
Will be selling apex springs shortly!
