Suspension?
Car  Sunshine Bus ph-quick
The naples (1.4 RT) has got lowering springs on it, I have no idea what/how low but I'm hazarding a guess at 35 or possibly 40 mm fronts.
Whoever did it, didnt bother with uprating shocks, and someone suggested a set of valver shocks would do the trick?
Is this do able, and is it going to make a difference to the standard shocks/lowered springs combo thats currently going on?
Ta!
Yeah valver ones will be better as they are around 30mm lower than an rt to start with.
I've already got lower springs Waitey, looking to uprate the shocks a bit.. but can't really be doing with buying a full new kit ATM.
HAve a look on Ebay for some second hand Apex or similar! Even brand new they're only £30 a corner, stop being a tight arse ;)
I meant that since valver suspension is 30mm lower the valver shocks will be well matched to your springs.
Don't bother trying to use other second hand shocks get new Renault ones.
Valver shsock are designed for differetn weight springs and engine. plus they will need modding to fit most likly due to them being 54mm vs 52mm spaced for your car.
