swapping digital climate control from cup setup
  RB 182
Is it possible to install the digital heater control in a 172 cup? I assume the fan blower will need to be swapped too as the cup uses cables to control the heat and direction. Are there any other parts that need to change over? Does the loom connect both types?
New interior loom and engine loom is different too from my experience.
You also need the box inside under the dash.
GrahamS
  335d, GT4
Need
Dash wiring, climate panel, heater box, climate control section of the climate loom and the blower motor inc resistor pack.
Takes quite a long time to swap it all over. Some of the wires are there like the connection to the ecu for the AC are there but it's a bigger job than the results are good.
