S13
As per my other post, I've got a problem in that I've got an old head unit and it doesn't have a remote out. I've given up trying to guess which is the switchable live into the back of it 'cos I don't want to bugger anything up so that leads me on to this question (unless of course someone can tell me which is the switchable live on my 98 mk2 ph1): Will a simple switch on the power cable do the same job? If I turn it off will the battery still drain out like it would when the power cable was just run to the amp with no remote wire thingy plugged in? Could anyone recommend the sort of switch I should use if this is the case please. I've seen some in Halfords over with their connectors and stuff, are these ok? The Amp is a Kenwood KAC-719.
As you can probably tell I've got no knowledge of anything electrical so simple words and colour codes would be preferable
Thanks,
Rob.
Thanks,
Rob.
