T/Belt Kit + Other Stuff
MarcB
  182 Trophy & 197 F1
Credit card is going to get smashed in the next few weeks and im doing my engine.
Now im almost 100% sure that my cam cover is leaking oil but looking through the parts catalogue there does not seem to be a seal for the cam cover and i have made a list of everything i think i need. . . . Is there anything more or less ?
My List of parts Needed -
Solenoid Valve – 82 00 539 626 - £55.94 + vat
Solenoid Valve Seal – 77 00 106 385 - £10.26 + vat
Plug Camshaft Seal – 77 00 274 026 - £4.49 + vat
Plug Camshaft Seal – 77 00 106 271 - £6.39 + vat
Ring Seal Kit – 77 01 471 629 - £21.39 + vat
Alt Belt Access Kit – 77 01 477 519 - £60.00 + vat
Timing Belt Kit – 77 01 476 675 - £145.00 + vat
List Of Parts Thats I Have Got -
NGK Spark plugs
Oil Filter
5L Elf Oil
  Clio Sport 172 Ph2
correct.... there is no rocker cover gasket. The best stuff to use to seal this is wellseal, i also use it on the k-series rover engine, as that doesnt have any gasket on the cam carrier.
Im going to respond to your question with a question ... Where do you get parts diagrams like that from? Sorry for going slightly off topic :eek:
And we just did a Megane cam change at work. Just used gasket maker as there was no gasket when we removed it ....All fine.
lemonnobby
renault sell there own sealer its blue coloured dont know the part number of hand.
i might get it later for you if i remember
MarcB
  182 Trophy & 197 F1
I used to work in the car industry and i was given a user name & password for HERE and its the same system that renault use.
It does any renault and gives you all information you need so i can look up all my car parts and part numbers and see how expensive things are before i buy them
  DON'T SEND ME PM'S!!
Mark, that timing belt price is wrong by £25 (should be £125.01+vat, which is already massively over priced)
put in a 172 cup reg number, and you'll be given a motrio alternative offer option. This is an SKF made cambelt kit which has the same warranty as a renault boxed kit
MarcB
  182 Trophy & 197 F1
Is it possible to get login details for this evening if not in the industry? Would save me pestering my dealer all the time :)
My login details dont change so if i was to hand them out people could go into the settings and mess things up and hand the password and user name to everyone so i dont hand it out at all.
If people want me to look up part numbers and prices as well as diagrams all they need to do is PM a reg for the car.
Timing belt kit was taken off an old invoice from when the car had the cam box seal done in 2005 with 2000 miles on the clock under warranty.
I am just going to buy everything from the main dealer and then i A) know its right & B) know that it aint cheap rubbish.
