T-cut!!
  197
I have just t-cut my car and there is still loads of small scatches noticable in certain lights, what have done wrong? I left it to set for around 3 mins as it said in the bottle.
  197
'T-Cut helps to easily remove surface oxidation, blemishes and mild scratches easily restoring the lustrous colour of your car in minutes.'
This is a quote from there website m8!!
The Boosh!
ClioSport Admin
  Elise, Duster
t cut is good to a certain extent, eg if you soak the scratch in water and you can no longer see it, then it will work.i took my car to a carwash once (BIG mistake) and it left loads of tiny scratches on the paint :( T-cutted the full bonnet, all gone :)you also shouldn't use it often as it cuts into the paint and makes it thinner.
Yosemite Sam
  Whichever has fuel
Use some products from Meguirs or Autoglym.
T-Cut has been around since 1950 and paint has changed a whole lot since then and as such, T-Cut is now frikkin useless.
  mk4 golf gttdi180
T-cut may have been around for donkeys years but they have changed there T-cut to work with newer types of paint i use t cut once a year to remove the dead paint from my offroad jeep and it really does work then i go over that with a polish/wax mirror image leaves it shiny and clean:) but ofr something like my clio id never use a product like it because i feel its a bit to cheap and it deserves better lol:rasp:
  Shed.
Utter s**t. Would you rub sand into your paintwork.. ??
Scratch X with a german applicator or the car lack kit. You really need to work the polish in mate, its not a simple method of apply and remove.
If you want a simple apply and remove method you can use Autoglym super resin polish, rarther than removing the scratches it meerly hides them with fillers to some extent.
Alastair.
  986'S 172ph1+182FF
t cut worked great on my mrs old punto, came up bright red and the finish was silky and it got loads of marks out
