Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
d/c battery for 15+ mins
look at underside of wheel
pop out clips holding in airbag
pull airbag forward gently
d/c airbag and horn
gently place on floor atleast 3 metres away.lol
use torx 40 iirc to undo but not all way,then pull steering wheel forward and off column
once off column then remove bolt then reverse for refitting
look at the back of the wheel,just to the left and right of the column,they will be the only 2 holes in the back of the steering wheel,need to push them outwards to unclip,easiest one at a time
Turn the wheel 90 degrees. Push the airbag in. Using a screw driver force the clip off. Then rotate wheel 180 degrees and do the same thing with that clip.
Airbag comes out then theres a torx screw in there. Undo it until the last couple of threads hit the wheel off and then undo the screw all the way for complete removal.
