TB Gasket
Car  Bumder With A Buffer
Anyone know the part number for the Throttle body gasket for a MK2 sport??
Got a new TB to put on and guessing I should change the gasket as well? Or if not somewhere to buy one from.
Choss
nah, its a paper gasket if its the one hes on about between the inlet mani + throttle body...
ive got it somewhere, gimme a few mins
from another thread on here as I cant find my reciept...
I need a gasket then :(
Would that make mine run in limp mode if there is an air leak there?
yeh the rubber is a seperate bit, round O Ring yeh?
This is the paper gasket between the throttle body and the inlet plenum, mine disintergrated when I took the TB off
Aye theres a red Oring on the TB itself. Wanted to change it at the weekend so guess il need to pop to renault!
So could that be a reason why my car keeps dropping into limp mode by having an air leak?
Right - Cable throttle body = paper gasket. DBW throttle body = o-ring which can be reused again and again if undamaged.
M
I swear I didnt notice one when I removed my tb to clean it 6 months ago... coming off again at the weekend so will see :/
