Fletcher
		I'm sorry, but thats nonsense. The 200 looks quite different. The 172 and 182 looked identical.
Yep from the front the 172/82 look exactly the same.
The biggest change is surely Williams to 172, and 182 to 197
Although when you read all these negative comments about the 200, a little glance to the left and you either see a 197 avatar or car details..
Yeh, but thats mk1 to mk2, mk2 to mk3.
This just just another phase. So like 172 ph1 to 172 ph2.
Talking s**t wthout substance again.
The gearbox is the same as in scenic etc etc.
Same chassis different springs & dampers.
At the end of the day you can quote what mag you like the most important part of any car is the 'nut' holding the wheel
Most likely BSing you fella. Renault would hardly do that level of work then not publicise it.hi, sorry to break the new but, I am not quoting any mag I am quoting the renault quality consultant that is in charge of the new gear box made in Barcelona for the rs200. Also he did do research and the chassis has benn completly reworked......
Are the 200's alot bigger than the 197's? I see a new style Clio on the way to work some days and it looks very big. Not Clio size.
Ahh right, tell you what I do like on the 200 is that cool yellow rev counter!
Ok here goes. Clear up some of the confusion and hate
200: The car is called a 200 because its 200 PS which converts to about 197 bhp.
197: The 197 is 197ps and converts to about 194 bhp.
The new clio 200 has 3bhp more than the 197 did.
The new 200 Cup chassis gets damper settings that are 15 per cent stiffer than the 197 Cup’s. Maximum power and torque remain largely unchanged.
The 200 has a revised 1st 2nd 3rd which are shorter.
The 200 has a new RevoKnuckle system used on the FRS which helps to eliminate tourque steer.
200 1204 kg
197 1240 kg
Hey and i drive a 200 and im well happy at the moment. A lot happier than i would be in a 197. It gets a lot of looks and none have been bad yet. Also only had good coments. It does look like a frog and its not pretty but its different from the norm and it dont look like a standard model. A mk3 clio went past me today and i couldnt tell if it was a 197 or a diesel untill it over took me as they look to dull.
Paul
I never said the 197 doesnt turn heads.
Paul
As Steve mentioned Stevo, the 200 has a different head, so I very much doubt the Renault map gives the same result. Why would they invest in the new head if that were so? And the cup packed car has a quicker rack as well.
