The blue NZ odyssey Project.
DLX
Car  Clio2 Ph1 172
Thanks for the Welcome, The Idea of this Post is to record the process of the car.
First of all some pics of how I took delivery of the car, Currently on 169000 km, Around 5 owners, no service History, but the previous owner said that the cam belt- daphaser and water pump have be change. beginning of this year.
https%3A//i.imgur.com/azcYOkd.jpg[/img]']azcYOkd.webp
https%3A//i.imgur.com/EjAPR7b.jpg[/img]']EjAPR7b.webp
https%3A//i.imgur.com/fKWkwIM.jpg[/img]']fKWkwIM.webp
https%3A//i.imgur.com/HPQyaRx.jpg[/img]']HPQyaRx.webp
https%3A//i.imgur.com/Owr152y.jpg[/img]']Owr152y.webp
https%3A//i.imgur.com/c2wo9np.jpg[/img]']c2wo9np.webp
https%3A//i.imgur.com/oT7LF0l.jpg[/img]']oT7LF0l.webp
https%3A//i.imgur.com/1hizdAQ.jpg[/img]']1hizdAQ.webp
Next due to water restriction in Auckland NZ ( Yes its 278 days a year and we have water restriction on the rainy season), Y decide to take the car off the road to star to tidy up the interior first.
So first remove seat, dash, door trims and pedals!
https%3A//i.imgur.com/vPxyBC0.jpg[/img]']vPxyBC0.webp
https%3A//i.imgur.com/gnpaglr.jpg[/img]']gnpaglr.webp
https%3A//i.imgur.com/qJ29drl.jpg[/img]']qJ29drl.webp
Finally Out!
Then decide to make a new pedal cover!
https%3A//i.imgur.com/WO2794E.jpg[/img]']WO2794E.webp
Start to refurbish the Seat with some liquid leather, leather dye, Fabric markers and a good Clean!
Passenger side:
https%3A//i.imgur.com/pVTp7qk.jpg[/img]']pVTp7qk.webp
Wow how did you repair the leather bolsters so well? Tips and product guide would be ace if you could share
Hi, for the Bolster I just clean it very well with isopropyl alcohol, thenI glue a piece of fabric on the back of the lether just to make it stronger.
then I apply some liquid leather from colourlock:
let it dry with the help of the heat gun.
and after that a couple o coats of the DYE leather toner number F039, Unfortunately in NZ i couldn't get the right colour like in the UK.
So I have to use the F039 that is close but not perfect.
Plus A lot of patience and try not to rush it and help it dry with the Heat gun.
the only cons is that you loose the grain of the leather. and I have not idea how long is going to last.
Hopefully this help you!
Cheers.
Great work! Think I'm gonna give that leather repair a go on a spare pair of seats I have
That’s an amazing job you’ve done on those repairs!
This will be one to keep an eye on.
Where abouts in NZ are you? Great to see something different over there. The year I spent over, all I'd see were Japanese and Holden or Fords.
Just read Auckland. Lovely city. My aunty used to live there before locating to Nelson.
Thanks for the comments, and yes not many renaults on the roads here and only a bunck 172, but I allways want one, so this time I close the eyes and grab the onlyone that was for sale. Obviously is not my daily due to avalability of part and cost for european cars.
Hopefully in the next couple of wekks I can start to put the interior back together and start to see how to retrim the steering wheel.
OK couple of small update, unfortunate due to the lock down, weather, maintenance on the other cars and waiting for small part I wasn't able to to advance as fast as I want it.
Trims before
http://
https:/i.imgur.com/fKWkwIM.jpg%5b/img%5d']http://fKWkwIM.webp
https:/i.imgur.com/nsLWeoN.jpg%5b/img%5d']http://nsLWeoN.webp
https:/i.imgur.com/27N73o4.jpg%5b/img%5d']http://27N73o4.webp
After
http://
https:/i.imgur.com/WoKagl1.jpg%5b/img%5d']http://WoKagl1.webp
https:/i.imgur.com/DmCukEG.jpg%5b/img%5d']http://DmCukEG.webp
Central trim back on the dash just waiting for new vents, both originals were broken and new foam on the air ducts
http://
https:/i.imgur.com/6pgdImE.jpg%5b/img%5d']http://6pgdImE.webp
https:/i.imgur.com/t8BQzdm.jpg%5b/img%5d']http://t8BQzdm.webp
Polish the instrument cluster
http://
https:/i.imgur.com/WvntnLs.jpg%5b/img%5d']http://WvntnLs.webp
Install the new pedals
http://
Pic of the refurbish seat on the Sun
http://
https:/i.imgur.com/ircb24Y.jpg%5b/img%5d']http://ircb24Y.webp
Unfortunately when trying to install everything the floor was all wet!
So remove carpet and just in there give it a wet and vac.
http://
https:/i.imgur.com/65bLQ3k.jpg%5b/img%5d']http://65bLQ3k.webp
https:/i.imgur.com/ICCmpsN.jpg%5b/img%5d']http://ICCmpsN.webp
So next will be to discover where the water is coming in ans seal , clean or do some voodoo magic to stop the water and start to put everything back together if I remember how it goes!
Thanks for reading!
New updated not a Big one But it was a non fun one to do.
First, clean the the center drain hose that was block / Hopefully no more water inside.
http://
http://
Second clean the floor and re Fit the carpets and Dash and Door Trims
http://
http://
http://
http://
3d Print same on ABS some center Wheel caps
http://
And last the more painful thing I have done in a car.
Re Trim a Steering wheel for Cheap.
http://
http://
http://
http://
http://
And Final Result:
http://
http://
http://
http://
And On the car With the Ali express Vents, that they don't move Up and Down. But they are in one piece.
http://
http://
Hopefully you enjoy, and definitely I will never try to do another steering wheel with cheap products from the Spotlight. Have been a nightmare.
Cheers.
Some really nice updates there mate. Seats look amazing!!
love the effort on the steering wheel, if only bits were easy to get over there, could’ve got a cheap seat and used the Alcantara and leather off that for it, but amazing result anyway.
After so long with out any updates this is how stands today.
First was time to find the closes match to the silver wheels.
http://
And start the prep, primer and Paint.
http://
https:/i.imgur.com/QsDCtrt.jpg%5b/img%5d']http://QsDCtrt.webp
https:/i.imgur.com/BzccYGa.jpg%5b/img%5d']http://BzccYGa.webp
https:/i.imgur.com/CeEl8s3.jpg%5b/img%5d']http://CeEl8s3.webp
Then due to don't have the time to make the 3d Print logos looking smooth I decide to remove all the tabs from the originals and 3d print new tabs and glue it on.
http://
https:/i.imgur.com/Eeaz6aG.jpg%5b/img%5d']http://Eeaz6aG.webp
https:/i.imgur.com/Oih2NOu.jpg%5b/img%5d']http://Oih2NOu.webp
Hey @DLX - Awesome thread, gave me some great ideas for mine.
Can you remember what colour code you opted for the wheel refurb mate? need to do mine soon :)
Just in case Somebody else is interest on the color of the wheels this its what I use.
Was the closes colour match on the cards that I have available.
Thanks! And your odyssey thread was a good inspiration to make it look as best that I can.
Cheers.
Mine looks terrible now tbh, it's still solid but the paint is fucked, needs a full hit tbh
This one is not perfect neither, but a Full respray will have to wait for a couple of years.
But just don't let your Ph1 die and keep the good work to have it on the roads!
