the missus car wont start - part II
Car  mg zs / alfa 147
OK
posted a little while ago
having issues with my missus 1.2 8v liberte
no spark, no fuel, no go anywhere :(
ok well i replaced the DTC sensor, replaced the coil pack (square block which the leads and pencil coils come off) but still nothing
sent the ecu away for testing which has come back as ok and was decoded to remove an immobiliser from the equation
plugs now spark but the engine don't fire so sounds like immobiliser
not getting fuel through the injectors but there is fuel pressure to the injector rail
any ideas?
i am thinking maybe the immob unit is still locking out the injectors
any idea how to disconnect this as the ecu will no longer be looking for it
lock the car then unlock turn the key to ignition lights leave for 5-10 m inutes and then it should start they have fuel pump problems sometimes especially if they are ran low hope this helps
its a liberte - doesn't have bleepy locking, its key in door old fashioned stuff
also doesn't even fire - there is fuel pressure, you can hear the fuel pump prime and if i pop the clip off on the end the fuel is under pressure
has only done 47K miles too so should be ok
any other ideas?
Off topic: Where did your username come from?
My car is known as 'Sonic' and my last digits of my number plate is 'RXG'
on topic: TDC sensor?
Does the car turn over?
Maybe try to press the red button under the bonnet? Had the fuel cut on mine when i hit a pot hole.
