The odometer does not appear
Car  RENAULT CLIO III
I have a problem with my car( REN CLIO III ) It is when I start the engine, the odometer appears for a few seconds, then disappears, and then the screen becomes like a digital wristwatch when the battery power is low. This photo I took from my car shows only the orange screen color without numbers.
Ah not ideal,
I assume you’ve toggled through the display with the button on the stalk to see if that works.
Only other thing worth checking is the fuses below the steering wheel.
Ah not ideal,
Tomorrow I will check the fuse, but I do not know its exact location, and it seems that I will use YouTube or the Internet.
Thank you for trying to help 👍
Looks like a faulty cluster. You could try these places on eBay where you send away for repair
I knew the reason, I just started the car, the numbers were there, but after a while they disappeared, due to the high temperature of the engine.
Looks like I'm going to take my cars to a car repairman 😔
