The Power PC Thread [f*ck off consoles]
N0ddie
  Tesla Model 3
I don't have a price in mind but I'm looking to shift it I think as it's not getting any use!
A quick marketplace look would suggest a price around £1800 to £2000. There are a few up here that are asking £2000 but second hand prices in Scotland are always a good bit higher than Englandshire.
Supply and demand I suppose.
Maccy
  Straight 6
Thanks, I’ve had a look around at some on marketplace and I think mine’s higher spec than most, in terms of components like PSU, case, cooler etc so I’m thinking around £2k
Rubicon_
  L110, RS6, Westfield
Anyone got a steam deck? Bought the oled one last night to kill some time when the kids are down / traveling. Looks a good bit of kit.
Ph1 Tom
Is around now the best time to get a RX 9070XT. Seen the ASUS TUF at just under £700. And the other ones around £600 or more like the Prime and Pulse. Is it better to have DP over HDMI or it, or does it not matter, some have 3 DP and 1 HDMI that’s all and some have 3 HDMI and 1 DP
Get the cheaper one. I prefer DP, then just have a HDMI for a TV if you want.
Beauvais Motorsport
My current setup. The case is a Fractal mood without the cover because it turns it in to an oven, I want to modify the internals so everything is more spaced out and remove most of the metal on the sides of the cover to create windows under the mesh. Currently Im building a workstation pc with a fractal terra and seeing if I could use a standard layout, It'll work for a single slot gpu which Ill be using but would be good to have the space for dual for whatever reason!
Fans will go other way this was just a mock up
Geddes
  Fiesta Mk8 ST-3
just placed an order on the Asus Prime it was going for £638 but i then cancelled it, as i don't think i'll get the pc built within the next month, i didn't want to take the chance if there was going to be any issues with it, or if i don't get to use it after that 1 month i wont get a refund. So I'll place the order as the last item within the 1 month of building.
Geddes
  Fiesta Mk8 ST-3
EDIT. I've bit the bullet and ordered it, RX 9070 XT Asus Prime while it was a good price and looked at the returns procedure and i'm happy now. I'm sure they won't be an issue when coming to fitting it. And it's the make and model to go for too for what i need.
Just need the Motherboard, Cooler and Power Supply now. Now looking at the B850 Asus Gaming Plus now and the Asus TUF 750w Fully Modular one and the Thermalright Peerless Assasin 120
Geddes
  Fiesta Mk8 ST-3
just got my Motherboard now and was startled that it wasn't in a box just in it's retail packaging. Should of said something to the driver or refused it. But i didn't, hopefully it will be ok when instaling
Geddes
  Fiesta Mk8 ST-3
It’ll be fine, as long as the box wasn’t crushed etc. Very common these days for things to be shipped like that.
cheers for the response, the box isn't damaged by the looks of it. I went on Amazon before and made a comment about it. I had a quick look at the board while still in it's wrapper and couldn't see anything out of the ordinary like bent pins and there's some cables and the paperwork is still inside. I was just wondering if the shock / vibrations of the shipping would of shoock something loose on the board other than the pins that was all. With it being what it is i thought it would of been triple layered in wrapping
I got my final components arriving tomorrow, Power Supply and CPU Cooler, once the arrive i got everything now, just need someone to help me build it.
charltjr
I totally get the concern, but it’ll be fine. These days Amazon put sod all packaging around stuff anyway so it would just have been a box in another box, next to zero extra shock protection.
Geddes
  Fiesta Mk8 ST-3
I'm just starting to put some files for the Motherbaord onto a USB file. From YouTube all i need is the LAN and the BIOS files? Is this correct, i did however transfer the Chipset and Audio Too but there's a few more files, I'm just wondering does the new pc auto find these for me and update itself ?
N0ddie
  Tesla Model 3
I’m panicking now a bit now and away for a bit so can’t really look properly, I’m not 100% now if I’ve ordered the correct ones for my AMD system, could someone tell me please if these do in fact fit AMD as it says in the description XMP iQue for intel , is my memory compatible for intel and amd??
Go to your motherboard's support page. There you'll see a list of compatible RAM.
Geddes
  Fiesta Mk8 ST-3
My main concern is the XMP / EXPO, the mhz and speed and is fine just not sure if mine is compatible for both or just XMP. Thanks
Will it show on the support page on there about that too?
It’s the B850 ASUS TUF Plus
Geddes
  Fiesta Mk8 ST-3
dones't matter now, I've orded the EPXO version now but it only comes in Grey not Black.
Can't return the one i have as it's out of the 1 month window
Geddes
  Fiesta Mk8 ST-3
These are the ram confirmed to work, doesn't mean if its not on there it wont work. But better for peace of mind to go with what works.
awesome thanks for that, it helped. Yeah the ones is have are CMK32GX5M2B6000C30 and there not on that list, so no good. The ones i just ordered are CMK32GX5MZB6000Z30 and they are on that list. It's a good job i know now but can't return them to Amazon, not sure if someone on here would like to buy them of me
Geddes
  Fiesta Mk8 ST-3
just got my deleiver of Amazon for the RAM Memory, the envelope had previously been opened , the label was pressing it down so i didn't know when it was handed over to me. Looked inside and it's not the RAM , I'm pissed, i've tried to look on Amazon for customer services telephone number, i've tried 2 but it gets you to recieve a text and I'm back to square one. I need a direct number to i can explain to someone there what's happened. Does anyone have a number by any chance?
Geddes
  Fiesta Mk8 ST-3
Yeah I popped on their site, had a brows. Their site is pretty well layer out, not bad prices, not far off Amazon prices. It would be awesome if could go to a place like that and have staff on site to help you build a pc. Is there any company’s in the North East that offer that?
charltjr
Scan will do exactly that, but you’ve got to get the parts from them.
I’d imagine most independent PC shops would be happy to take you through a build, but I suspect the problem you’ll have is not having bought the parts from them - who’s liable if something doesn’t work etc.
Building a PC is honestly a piece of piss though. Just go slow and don’t be afraid to take stuff out again if it’s not going right.
N0ddie
  Tesla Model 3
Unless you want a cutting edge GPU, then they take your money instantly and fob you off for 3 months! 😂
Overclockers UK 👌😂
Didnt OCUK take peoples GPU money for longer during the 30 series debacle? They are both as bad as one another. Too many folk suck right up to that Gibbo c**t on the OCUK forums. Its vomit inducing.
SharkyUK
No idea, fella - but it wouldn't surprise me. To be fair, the 5090 issue I had with Scan was the first problematic transaction I've had with them, and I've been a customer since they started many moons ago. Never had a problem with OCUK either, but I've bought less items through them. I've seen Gibbo mentioned and he's replied to a couple of my car threads, but I have to admit I don't know much about him!
Wilkeh
  MK4 Anni & MK5 Edt30
Some dollar spunked on that processor! Just for gaming or a bit more on top?
Wasn't too bad really, got it in the Prime deals and also had a voucher. I know that the 9800X3D performs just as well (and sometimes better) for gaming but yolo, I had some spare dollar burning a hole in my pocket!
Going to top it off with a 5080 Ti / Super when they come out
Geddes
  Fiesta Mk8 ST-3
I’m still using my Logitech G5 mouse and it’s been awesome, the right button has been playing up for some time and ive repaired it few times but it keeps coming back. Think it’s time for a replacement, looking on their website I think the G203 or the G403 are my options, what are these like compared to my G5?
or even the g502, looks like a bat mobile
Ph1 Tom
I changed from the Logitech G5 to a Razer Deathadder.
You can get wired or wireless. I've had both, the wire is very flexible so you don't notice it and it's a bit cheaper than the wireless one. I'm currently using the wireless one as I got a good offer on it.
Ray Gin
  Tesla & Impreza
Tempted to try a different keyboard and mouse setup. Nothing particularly wrong with what I’ve got, they’re just a bit old and tired looking now.
Currently rocking Logitech G915 TKL and the G502 lightspeed mouse. I’d like a 60% keyboard just for more room.
What are people using these days?
