The Power PC Thread [f*ck off consoles]
SharkyUK
Okay so..
1. Pretty much yeah freezes up a bit and then restarts no blue screen or anything
2. I've literally only played arc raiders over the last few weeks but I'm sure it happened before with BF6. Usually after a long sesh.
3. Pretty much this build so Ram is pretty low but generally been okay for years now.
4. Yep xmp enabled but that's all I've done. Not any proper overclocking.
5. I'll have a to figure out how to check that 😂
I did a while back now turn the fans down because they get annoying although should be at 100% anything over 75-80c. Maybe that's my first go to try and resolve also will look at event viewer and see if there's anything obvious.
I have seen similar behaviour when the power supply unit has been on the way out, or when too much power is being drawn from, for example, an overloaded power strip. The sudden drop in consumption can trigger cut outs and restarts. There are sometimes power related events shown in the event viewer (if that is the case).
Matt Cup
  Leon Cupra, 172 Cup
Razer kraken kitty for gaming (ears are useful to keep the hood up on a hoody)
Crinacle Zero:red IEM's for music (decent quality and cheap
Logitech Z150 for general youtube
.Joe
Okay so..
I had a similar issue with an asus tuf motherboard
It ended up being related to the motherboard anti surge protection
I ended up replacing the 750w psu with a 1100w fsp 80 plus platinum and the cut outs stopped
Adamm.
Thanks mate I'll take a look in the event viewer see if there's anything obvious and go from there. I'll check all the power cables too make sure everything looks okay.
Adamm.
I have a bunch of critical events saying kernel-power does this point to the PSU you reckon then? Does seem so. I'll try a few things and see how it is over the next week if it keeps happening I'll replace it.
SharkyUK
Kernel-Power 41? If you are seeing a lot of those, that confirms the sudden and unexpected power loss - where main culprits are failing PSU, RAM, overheating. More often than not, it is power supply related.
There are a few things to try. Firstly, plug the PC directly into the wall socket (rather than from a strip extension, if applicable). Use separate PCI-E cables internally - avoid daisy-chaining. Also, try installing MSI Afterburner and dropping the power limit down to something like 80%. See if that "fixes" things.
An interesting thing to note, too... the recommended PSU for a 3080 Ti is 850W. 750W with your CPU and GPU is borderline, especially if the system sees transient spikes and the PSU cannot handle it. Sustained loads (whilst playing the actual game) can be dealt with easier than managing fast transient oscillations in power spikes (which can happen when exiting a game, for example).
Adamm.
Appreciate the help mate taking notes and going to test and monitor maybe a few weeks but will update how it goes. For now I've just reinstalled a bunch of drivers and turned the fans back to turbo in the bios as I did recently turn them down.
Will see if I still crash before I try a few other steps to try and narrow it down through process of elimination maybe.
Daz...
  Inferno 182 Cup
Try limiting the power in MSI afterburner. If it doesn’t give you any issues with the GPU set to 80% power limit you’ll pretty much be sure it’s the PSU.
Adamm.
Yeah I have the GPU turned to 90% but will crank it another 10% and see.
Daz...
  Inferno 182 Cup
I’d look at 850W and 1000W, see what the price difference is. If it’s negligible then it’s always safer having a bit more headroom.
Adamm.
So looking at the new PSU I'll probably just spend the extra and get the 1000W one. The wiring setup is different I noticed so I'm guessing everything will need to be wired up again. Is this a fairly simple task? This is my first PC and is a pre built so I'm a noob when it comes to PC building but I'm willing to do it myself aslong as it's fairly simple.
I'll pull the back off over the next few days and have a good look.
Adamm.
You will need to redo the wiring as it’s not recommended to use cables that didn’t come with your PSU, they can even be different between models from the same manufacturer.
Cheers annoying really as it went past it's 3 month warranty a few months ago. I'm hoping I don't have to take it all to bits to do that lol.
Daz...
  Inferno 182 Cup
Just do one at a time, remove an old one and replace.
It’s honestly not difficult, just make sure they’re seated fully when plugging them in.
Speedo Gonzales
Yeah please don't re-use old cables
The pinout on the PSUs change quite a bit. Corsair list which cable kits you need and which PSUs are cross-compatible in their pinout too. Sometimes you can get lucky on just swapping out the power supply itself but most of the time if you're upgrading it's always best to be sure and just buy new cables
Darren S
Have the prices gone mental now aye?
Did some parts changing recently.
Paid more for 32GB of DDR5 than I did for a 9800X3D CPU.
The flip-side - made £100 on the 5800X3D I sold, over what I bought it for about 18 months back. Bought for £250, sold for £350.
The biggest surprise was with the DDR4 kit. It was 64GB tbf, but at a pinch, I was suspecting I might get around £100 for it as it was nothing special spec-wise. Nope...
The one part that doesn't seem to have changed are the DDR4/AM4 mobos. I think the spare one I now have is only worth around £70-£80.
ChrisR
Had been putting off a bit of an upgrade for months, yeah that’s gonna bite me in the bum now with prices as they are 😂
Plan is maybe to go for a minor upgrade to just update everything to something a bit more up to date but nothing amazing performance wise (but still better than what I have now).
Current thinking is reuse my ddr4, am4 mobo, 5700x (an x3d preferred but hard to find now), and possibly a 5060ti 16GB.
All relatively meh stuff compared to a lot of builds, but I’m coming from an almost 9 year old 7700k and GTX 1080.
I only game at 1080/60Hz at present so if I do actually but the bullet on this then it’ll do me nicely for a while, and should be a cool/efficient little build.
Daz...
  Inferno 182 Cup
Upgraded to an OLED monitor today.
The ROG Strix XG27ACDNG to be precise, just rolls off the tongue like all of them do.
It’s a 27” 1440p that goes up to 360hz and looks bloody amazing tbh.
The picture I have is below, it’s really bad, but that’s it against my old IPS monitor.
In summary - if you haven’t already got an OLED and your main use case is gaming…do it.
Daz...
  Inferno 182 Cup
I've always been concerned about screen burn, but would definitely consider a 39" 5K2K one
This is what’s always been on my mind, but the newer ones with the pixel cleaning/refresh pretty much negates the worry.
Also, the 3 year warranty helps.
ChrisR
Upgraded my little toaster as it was getting on a bit.
Intel 7700k + GTX 1080 out (@SharkyUK the 1080 did me good for however long ago I bought it off you!)
AMD 5800XT and 5070 in.
(And a new psu as it was on offer)
Only a modest update trying to make use of my existing ddr4.
Won’t set any records for performance or anything, but running the cpu in eco mode keeps it nice and cool and hopefully quiet!
SharkyUK
Nice and tidy! I'm glad you got a good run out of the 1080 fella! :cool:
