Think my Clutch is...
Car  E60 diesel powah
Slipping!! :( i rest my foot on the clutch..even tho its light pressure being made..the clutch dips and engine starts to rev!!
You can get a new clutch from europarts only £35 its German made..which means it will last longer than a renault part that cost about £70 from europarts.
Hold the hand brake on, lift your foot of the clutch gradually if the 'bite' point is really high your clutch is on the way out..
new clutch from renault was £60+vat last time i ordered 1 for a 1.2 16v, its not really a hard job to change if you have the tools, if your paying labour then ben_p probably right with £300 ish
Get it up to 30mph on the flat and stick it into 5th, then floor it.
If the revs rise and the speed doesn't your clutch is fucked.
I have (helped) change one took two days but we didn't have a hoist.
A few of us lifted it back into place..and it was blinking heavy..even on such a small car.
Basically my legs were sticking out the top of the engine bay..as I was getting pulled in..lol.
not actually resting my foot on it! just hovering over it, i can tell its on its way out, the bite is high already, ive been driving slow everywhere at the mine, Pinky you got the EuroParts website??
Need to order one asap!
they arent too bad to do on the floor i did mine on the floor provided you have an idea of what you are doing you should be fine.
can do non sports on the floor in 3hrs.
as for it being heavy - try changing a clutch on a 3l capri with a cast iron bellhousing trying to lift that out on to your chest...
are the clutches on clios commonly quite high?
when i bought mine the guy said it had a new clutch put in, but the biting point was so high. is that just normal for clios?
i had a new cluch fitted to my mk2 ph1 1.2 clio last month all in fitted it was £224.85
dealer or private garage?
i assume not dealer unless they forgot to add a zero lol
need to get mine done apparently but seems alright to me at the moment. just uber high
probably worth doing the clutch cable while your at it mate, i changed my clutch then done the cable a month later and what a difference it made to the pedal feel, much lighter!
private garage i didnt want to think how much renault would charge me lol :)
