Throttle body question regarding clio 172
  Clio 172
Hi all,
I believe the throttle body on my clio 172 needs replacing.
If I purchase a 2nd one and fit it myself will I need to have anything re-programmed or mapped for it to run correctly?
Apologies if that's a stupid question.
Many thanks,
Dan
  Clio 172
Thanks very much.
It looks like a fairly simple job. Has anyone done this? Are there any complications?
James
  Clio 220 Trophy
It's easy mate, whip the airbox and hose out, unplug the connector, 4 bolts on the throttle body and remove :) fitting is just the opposite
  Clio 172
Make sure the one that comes with it has a gasket, or make sure you keep the one off your old one. IIRC when I took my TB off, the gasket was still stuck on the car
  Clio 172
Hi all,
Thank you for all your replies. Sorry for the delayed response!
I have purchased one tonight so I will be fitting over the next week or so. In the mean time I,ve cleaned up the old one and she seems much better.
Dan
