throttle body...
Car  Tweaked Leon Cupra R
errr. houston we have a problem!!
i just had ma throttle body off cleaning it and during assembly i tried to shoe horn the chamber that the oil breather goes back into the gap between the block and the bulkhead..
anyway, i have broken the linkage between the main lever on the throttle body and the bit that opens the valve..
Can this be stripped and replaced or is it a whole new tb unit? i dont have torx bits to fit the throttle position sensor so cant interrigate it anymore.. :(
and if so, where can i get one tomorrow!? (in aberdeen)
Is it a scrappies job. and should i just go for the one of the 2.0l megane/laguna instead of the 1.6 k4m? as they are the same size arent they, just a bigger bore?
I'm not sure what you mean do you mean the throttle cable is damaged? Or the half moon bit which open the throttle body?
