Now this is just the engine light,Bump as I have the exact same problem,
We think it's temperature related.
So the engine management light has been on forever, we have plugged it and these are the faults found ( and if you Google, you'll realise it's pretty much the same on other cars soo must be common, but what's causing it?)
9 wheel speed sensor front left circuit
285 fast fan control
266 02 sensor before CAT
301 brake pedal sensor circuit
309 cruise control /speed limiter brake pedal switches
257 throttle body valve position circuit.
I know it was ages ago, but some of us still keep them old cars and cherish them.. What would you suggest might solve the issue?On a 172 Cup this is 100% a wiring fault and 100% NOT a pedal or TB fault so if you have cash to throw away i'll send you my paypal details and you can load it up as much as you feel like.
It's normally due to a connection fault either at the TB itself or somewhere between the pedal and the ECU. We do loads of them and its always the Cup that seems to be effected. Enjoy searching it out but I promise you it's a simple enough fix once you find it.
Mick
It really depends on the actual fault as they all manifest with the same symptom but the diagnosis can be slightly different. Ultimately though, constructing a new mini loom from pedal to ECU and then ECU to TB works great (Depending on the ability of the person building the loom sections).I know it was ages ago, but some of us still keep them old cars and cherish them.. What would you suggest might solve the issue?
Did you ever overcome this issue? I have a few select issues that are similar, mainly the fact that the car is fine when up to to temp or in the warmer months. Now I’ve got constant limp mode in the colder months until the car is up to temp.Now this is just the engine light,
When cold, below 5 degrees, the zigzag electric light comes on,
Car then starts and drives in limp mode, starts by revving itself from 2,5 to 3.5 revvs, won't go past that, I basically have to drive with my foot on the brake instead of gas, it's unresponsive if I step on gas pedal. Once warmed up, I can pull up, switch the engine off and start it again, the zigzag gone away it drives fine.
It had the engine light management reset which lasted for a day, after the electrical light came back in this morning, engine light is on again.
We have checked the throttle body and the wire that feeds it and it looked OK (assessed by my lecturer so they know what they were doing).
Zigzag fault is definitely temperature related, as I had it sitting for weeks over the summer, and it started just fine, also starts fine after sitting for a few days in temperatures like 7 degrees.
Soo, what could cause this?
Them 2 faults are defo related, engine management with the electrical zigzag, but it escalates in the cold.
Any idea as to what to look at??
Any insight would be much appreciated.
Right now it's a right pain, it's minus temperatures over here, i feel really sorry for the car. Luckily mine only goes onto limpo mode once, then once its warmed up I can stop and restart it and it runs fine - electrical fault away. Unlike some people on here reported their cars randomly going into limp mode while driving.It really depends on the actual fault as they all manifest with the same symptom but the diagnosis can be slightly different. Ultimately though, constructing a new mini loom from pedal to ECU and then ECU to TB works great (Depending on the ability of the person building the loom sections).
Does your limp mode go away on its own? Cause I need to stop and restart. So sometimes it takes a minute, but sometimes I drive it for some time, and it must be warm already because when stopped and restarted then the fault has gone away, so it's like it's an open loop or something.. Does your car throw the MIL light too?Did you ever overcome this issue? I have a few select issues that are similar, mainly the fact that the car is fine when up to to temp or in the warmer months. Now I’ve got constant limp mode in the colder months until the car is up to temp.
No it doesn’t go on its own, it will be up to temp and still in limp mode but when I stop and restart it then it’s cleared and fine. And yes but not everytime, only if it’s upset by the sparadic idling or cutting out. Sometimes it won’t show the MIL. I take it a year on as once as it got to the warmer months it was fine so you left it?Does your limp mode go away on its own? Cause I need to stop and restart. So sometimes it takes a minute, but sometimes I drive it for some time, and it must be warm already because when stopped and restarted then the fault has gone away, so it's like it's an open loop or something.. Does your car throw the MIL light too?
So the limp mode is just like mine, only mine has had the MIL on ever since I got it. Yeah I didn't bother in the summer months because it's so hard to actually even explain to someone what's going on. I mean the fault will have gone away by the time I get to the garage soo.. No one has ever plugged it with the zigzag onNo it doesn’t go on its own, it will be up to temp and still in limp mode but when I stop and restart it then it’s cleared and fine. And yes but not everytime, only if it’s upset by the sparadic idling or cutting out. Sometimes it won’t show the MIL. I take it a year on as once as it got to the warmer months it was fine so you left it?![]()
The only thing that seems different is the brakes seem to have no relevance with my issue. I had it plugged in when the zigzag come on and it doesn’t show anything further thanSo the limp mode is just like mine, only mine has had the MIL on ever since I got it. Yeah I didn't bother in the summer months because it's so hard to actually even explain to someone what's going on. I mean the fault will have gone away by the time I get to the garage soo.. No one has ever plugged it with the zigzag onI take it the person who sold it to me knew about it but didn't say a word. I'm defo going to have someone to have a closer look at it, the electrician suggested it's most likely the electrics as I was thinking of cleaning out the throttle body as well.
It does struggle to start sometimes, it'll crank until I depress gas pedal. Erratic idle too but it's been pretty reliable, except for when it throws the zigzag light![]()
Oh well done, you've done a better job than IThe only thing that seems different is the brakes seem to have no relevance with my issue. I had it plugged in when the zigzag come on and it doesn’t show anything further than
257- Throttle Valve Position Sensor Circuit Coherence Between Track 1 And Track 2
I’ve never had an issue with mine starting, starts on the key first time no issues. What have you tried so far? I’ve cleaned all fuses ,relays and the white connector. Cleaned the throttle and brake pedal sensors. Cleaned the face of the throttle body (will be taking it off to do the whole thing)
Once not was *I'll definitely look into that, i think we're going to strip the wiring too but TB would do with a clean out regardless. I'm lucky because like I said in previous posts, my car doesn't go in limp mode randomly, it'll only happen when I start it in the cold and once warmed up and started again I can run it all day and the fault won't be there. So it's been fairly reliable even in temperatures below zero, was it gets warm. I would not like to have it go into limp mode out of the blue on the motorway or something
Yeah that's when it's bad, I had it come on at the start of a long journey back from Manchester, would not go off as much as I tried restarting the car. 65mph or so was as quick as I could get it, just quicker than lorries, but not quick enough to get past them in a timely manner.I'll definitely look into that, i think we're going to strip the wiring too but TB would do with a clean out regardless. I'm lucky because like I said in previous posts, my car doesn't go in limp mode randomly, it'll only happen when I start it in the cold and once warmed up and started again I can run it all day and the fault won't be there. So it's been fairly reliable even in temperatures below zero, was it gets warm. I would not like to have it go into limp mode out of the blue on the motorway or something
Certainly can't have been a fun drive, sorry to hearYeah that's when it's bad, I had it come on at the start of a long journey back from Manchester, would not go off as much as I tried restarting the car. 65mph or so was as quick as I could get it, just quicker than lorries, but not quick enough to get past them in a timely manner.
That wasn't a fun drive home.
I've done the same trick this morning. 3 degrees outside, zigzag on. Held the pedal depressed for a few seconds. Kept switching the ignition off and on until the zigzag went away. MagicStrangest thing happened this morning, 5 degrees outside here. Went to start the car and obviously the zig zag was on. Switched the ignition off, depressed the pedal, switched it back on, and boom,as if by magic, the zigzag was off. Started the car and drive off with no issues.
What's going on here
Great work! I have replaced my throttle pedal, it didn't fix the issueSo I currently have this issue.
Things I've done so far:
Unplugged the white block connector at the bottom of the fusebox, separated the blue connector from inside the block connector on the female side.
I continuity tested from the throttle pedal loom to that blue female connector. Can confirm I had continuity on each pin.
I then continuity tested between the male blue connector to the ECU and had continuity on each pin.
I then did the same from the throttle pedal plug to the ECU.
I tried a new throttle body and had no luck.
I tried replacing the inlet temperature sensor. No luck.
My last bet is to try a new throttle pedal and see if this works.
Shame the owner of the post didn't post the solution.
Also the inlet temperature sensor, doesn't fix the fault in the cold. Again I'm lucky cause once warm I start the car again and the fault doesn't come back on, can drive it normallyI have replaced my throttle pedal, it didn't fix the issue![]()
Have you continuity tested your wires?Great work! I have replaced my throttle pedal, it didn't fix the issue![]()
No I did not, never got round to it although I definitely should check continuity. My limp mode won't go away on its own, but I figured if I stop the engine and start it once it's warmer, the fault isn't there. So I let it sit in limp mode rev like crazy for a couple of minutes (sometimes longer) then restart. So I would say it's definitely temperature related, but how exactly I don't know.. And why would the ECU not switch limp mode off on its own once the engine gets warm, it's like I have to reset it manuallyHave you continuity tested your wires?
I've just ordered a pedal. I'll keep you updated.
Mine is in limp mode from start up and will not go away![]()
