Tightening aux belt?
Car  LY R26
Hi, my Clio 172 Cup is on 31,000 miles.
The aux belt when I start the car lets out a squeak sometimes (at max 1.5 seconds long)
..The belt itself looks in good nick. Im going to get it changed in 5k miles, I just wondered, is it easy to tighten the belt / can it be tightened?
....someone suggested fanbelt squeak spray but this sounds a reet bodge.
If someone could talk me through how to do it (if possible)
that would be much appreciated.
really?
is there a guide on here or whatever?
Renault wants me to pay £400 for a belt and tensioner change....
oh so its built into the alternator,
and I dont have a tensioner on the cup as I dont have aircon?
...any guide on how to tighten the belt? or do i just have to buy a new belt?
you just slack off the 16mm and 13mm bolt, then using a deep socket slack off the 10mm bolt (coat it in wd40 first, its the worst bolt in the world)
then re fit the new belt as per the one you removed and re do the above 13mm and 16mm bolts to "tight" then wind the 10mm bolts up until you can twist the belt 45 degrees with your finger and thumb on all runs
