time to spend rebate
Car  clio182
Hi was looking to get some eibach pro were is the cheapest and how much.
also sportlines are lower than pros beacuse I only really want it 20mm lower ???
Sportlines lower approx. 45mm at front and 30mm at rear, Prolines will drop you 30mm all around as far as i am aware. Not sure where will be cheapest; try fleabay, your local motor shop, traders on here, other online retailers??? I think r.r.p. is about £140 for a set of either.
In reality on a 1*2 its 25mm Sportlines 15mm Prolines i think kam racing are cheapest mailorder
I have sportlines and they are spot on not too high or low
cheers think its going to pros don't want it to low 15mm will look more standard and with a bit better road holding
I read that three times and still can't work out what you're saying. I'm not being a grammar Nazi (well, I am), but seriously, at least use punctuation to break up the sentence.
