Process:: just to make sure im doing it right before i start....
Turn over to to tdc so pin goes in(if u look through hole you can see key way)
Belt off
horseshoe in if doesn't fit turn cam sprockets to get in position for horseshoe to fit
put 1509 tool on cambelt side. Lock sprockets. Undo both
leave finger tight
belt on. Tension belt
remove all tools, rotate belt backwards by Turning over bottom end...?
check tension
1509 back on
tighten up cam sprockets.
Done?
Also where the belt goes over the crank, this was loose and moving freely untill i put bolt back in? is that normal?
thanks!
Belt off
leave finger tight
check tension
1509 back on
Done?
thanks!
