Tips on easy removal of brake servo ?
Car  clios
I have a 2002 1.2 8v clio that the brake servo has come apart ! IT looks awful to remove ? On ebay i have seen the servo for sale with the pedals is it easy to remove that way ? i have a 1.2 16v car i am going to remove the parts from.
I've just removed one from my 182, I can't imagine them
being much different tbh.
First off you'll have to remove any heat shielding/matting that sits in the way or at least pull it back so that you can gain access to the servo/ master cylinder etc.
Next remove the vac hose from the servo that goes to your inlet manifold.
Then disconnect the clutch cable, either from inside the car in the pedal box or from the clutch fork itself (if done the latter way you'll have to pull it through with the whole assembly after feeding it around the whole engine bay, from the inside will be much much easier).
Next drain as much fluid as possible from the brake fluid resevoir, I used a large syringe and a bit of thin tubing so I could get as much as possible out.
Next crack off the brake lines going into the master cylinder and then pull them out, there will be some fluid in the ports too as well as the lines so pull as much as you can out of the ports and cap the ends of the brake lines to prevent it dropping everywhere.
Now move inside the car and look under the dash, you'll have to pull some carpet about I should imagine and possibly some sound deadening from around the pedal box to gain access to the bolts holding the assembly in place.
Remove any electrical plugs such as the throttle and brake/clutch sensors.
Now you can undo the nuts/ bolts that are holding the pedal box to the car, once these are all removed you should be able to remove it from the car by pulling it towards you and out under the dash, just make sure that nothing is caught or preventing you from removing it fully. Put something down to stop any excess brake fluid leaking over your interior too.
Hope this helps you out mate, like I said this was on a 182 so may be slightly different but I can't imagine it myself, I also had everything out of the car including engine, interior etc so made it quicker and much easier for me so just be careful and check before you go to remove it.
Hi
I have done the job now i managed to leave the master cylinder on the car and fit the servo, the car now has brakes !!
