Torque settings - Top Engine Mount
Car  #174
Remember seeing it on here but can't find it now, just wanting to know how tight the 4 bolts holding the top engine mount need to be (in Nm)?
Think it's 62Nm for the 4 bolts and then 44Nm for the single nut... Guess I can always adjust once fitted.
old thread bump.... just to confirm is it 62 for the three bolts on the engine side too? that's what i'm getting from the linked manual but it's not clear, and i don't want to strip the threads. this pasted from the link:
Sub-frame front mounting bolt 6.2
Sub-frame rear mounting bolt 10.5
Front right suspended engine mounting
cover to engine mounting bolt 6.2
cover mounting nut 4.4
Rubber engine mounting to front left side
member support mounting nut 6.2
Gearbox lower rubber mounting
mounting nut 4.4
Shock absorber base mounting bolts 18
Brake caliper mounting bolt 4
Steering shaft yoke mounting bolt 3
Wheel bolt 9
