RS RIP
I've read the oem torque-setting on this on is 44NM (?) The OEM mount had a "square" hole where the engine-part of the mount would precisely slide/fit over.. The Vibratechnics has a round hole, with room for play : the bolt has movement in it even when tightened up. I can see metal shaving from the movement , not good.
Would there be a problem to tighten it some more ? Logically i would be pressing down the rubber, also nog the ideal situation.
I've checked the Vibratechnics site, no specs mentioned there..
