Scattle
Nissan R35 GTR
Hi all,
Thought I would show a few progress pictures of my dads Toyota Supra build that we are currently undergoing.
It is a home build and him and me (when I can help out) are doing all of the work to the car ourselves.
The build actually started in December 2012 that was when the Supra was taken off the road for work to start.
The car has been owned since 2005 and is a standard Silver Twin Turbo Auto Aerotop (removable roof). The decision was either buy a new Nissan GTR or do something to the Supra.
There's 100's of photos but I'm only going to put up a handful as otherwise it would take me forever!
This is the spec list that my dad is going for.
Engine:
8200 rpm rev limit
Mahle Pistons 86.5mm
Brian Crower BC625+ con rods inc ARP fasteners
ACL Race Bearings
Titan Billet Main Caps
Fully balanced internals and polished crank
Stock crankshaft
Welded crank sprocket
ARP Main Studs
L19 ARP Head Stud Kit
New stock water pump
New stock oil pump
Toyota complete gasket set
Toyota stock head gasket
HKS timing belt
Billet tensioner and idler pulley
Titan adjustable cam pulleys
Whifbitz 72 degree thermostat
SRD Custom Breather System
Blitz Oil Cooler
PWR Radiator
Twin kenlowe Electric Fans
Titan crank pulley
TRD engine mounts
Stage 5 SRD Ported & Polished Head with:
Ferrea Manganese Bronze Valve Guides
Ferrea 1mm Oversized Competition Plus valves
Ferrea Valve Seals
Ferrea Dual Valve Springs
Ferrea Titanium Retainers
Ferrea Spring Seat Locators
Ferrea Valve Locks
SRD stage 3 - 280° 10.2mm lift Cams
Turbocharger & Induction:
HKS Twin GT2835 Turbo Kit,Water cooled
Turbo Spec 52t, .73 AR Hot, .50 AR cold - Rebuilt by Owen Developments
Twin HKS heatshields
Twin HKS 50mm racing wastgates
SRD Custom Intercooler
Twin HKS SSQV Dump Valves
Veilside Plenum
Veilside 100mm Throttle Body
Fuel, Tuning and ECU:
Twin Walbro Intank Pumps
Titan triple Fuel Pump Hanger
HKS 1000cc Injectors
HKS Fuel Pressure Regulator
Paxton High Flow Fuel Filter
SRD Custom Fuel Lines
Veilside Fuel Rail
3.5 Bar Map Sensor
Syvecs S6 ECU
Exhaust:
4" Boostlogic
Drive train.
SRD built autobox
3200 hi-stall torque converter
Twin SRD transmission coolers
SRD Flappy Paddle Transmission behind steering wheel
Suspension, Wheels, Tires & Brakes:
KW Variant 3 inox-line – Perfect Street Performance
8pot 356mm Ksport front big brake kit
4pot 356mm Ksport rear big brake kit
Not decided on wheels yet.
Interior:
New Heater matrix
Retrimmed Standard Seats
All interior panels covered in Alcantara
Exterior:
Colour: Lamborghini Arancio Argos
Stock body withMVP Motorsports Front Lip
RMM (Rod Millen Motorsports) MKIV Supra Wing with Carbon Fiber Center
Zunsport front grille set
Facelift rear lights
Facelift front indicators
smoked side repeaters
This set up and spec should be around 1000bhp give or take.
It started by removing the engine and gearbox from the car back in December 2012
I'm skipping a few steps but will explain,
After the engine was removed from the car, it was disassembled and the crank, bearings, pistons, rods and all ancillaries were removed, when it was a bare block it was sent to Roland Alsop Engineers to have the bores slightly bored out, the main caps slightly skimmed, all pistons and Rods balanced, the crank balanced and polished and the block thoroughly cleaned , this was around April 2013.
Whilst the engine was away, me and my dad made a start on stripping the car ready for it's respray and overhaul.
Everything was gutted so the car was just a shell including front and rear suspension, brake and fuel lines, glass removed etc.
Once this had been done the car was put onto homemade casters so it could be wheeled around the garage as it had no suspension.
We now started on smoothing the engine bay, this took forever and was hard work, all holes which weren't needed were welded up then filled over and then primered.
This is the car now ready for respray and the engine bay fully smoothed.
The car was sent on a transporter to a company in Rochester Kent for the respray.
Whilst the car was away, the fuse box relocation took place, this was being moved from the engine bag to the boot behind the rear seats, this meant lengthening 46 wires and individually soldering them all back
Up again.
Also whilst the car was away, the front suspension was overhauled, all new drop links, track rod ends, all new r2 bushes were pressed in, along with steering rack bushes and all of front suspension components including subframe were powder coated in silver and the front arb was powder coated red. This is upto November 2013 more to come soon.
Engine:
8200 rpm rev limit
ACL Race Bearings
Stock crankshaft
ARP Main Studs
New stock oil pump
HKS timing belt
Blitz Oil Cooler
PWR Radiator
Titan crank pulley
TRD engine mounts
Ferrea Valve Seals
Ferrea Valve Locks
Veilside Plenum
Veilside Fuel Rail
3.5 Bar Map Sensor
Syvecs S6 ECU
Exhaust:
4" Boostlogic
Drive train.
SRD built autobox
Interior:
New Heater matrix
Exterior:
Up again.
