Chase Racing Clio
So....I have had this Toyota Supra for a bit more than a year now, but it started to burn lots of oil (it is 20 years old) and so, I bought a 2nd car (the Clio of course...) so that I could work on the Supra!
This is the Supra, on the way to Le Mans in 2010:
The aim of the project is to fully rebuild the engine, with mostly standard components but to a high spec. It's a 3 litre straight six engine, with a nice turbo, so I'm looking to get 300bhp....I'm not gonna go too crazy.
The first step, is to remove the bumper for better access
Then, it's the simple matter of clearing the engine bay to free the engine
Next prep the car ready to hook the crane up (yes, that's me)
Then, we can start to pull the lump out, being careful to make sure everything is disconnected as we go
Finally, after much tugging and straining, the engine and gearbox are out and we can get ready to strip it down
Gearbox disconnected
Then, we stick the engine onto the stand and get stuck into pulling off some more components
The head is off
As you can see, the rings have clearly worn as the combustion chamber contains quite a bit of baked on oil
Now, we measure the bores to see how much material is left and how much we will need to bore the cylinders by
And once the bores have been measured and the pistons removed, we work our way to the bottom end and measure the big ends
That's as far as we've got so far, next step is to spec up which components are required so that I can order them. Then we can get the block, head and crank to the machine shop.
I'm gonna try and keep this up to date. The target is to get the car back on the road before winter sets in, so ideally september/october time.
The head is off
