TP-link Deco Reoccurring Issue
Andy_con
  clio 182
It's getting to the stage where I'm going to have to bin off the deco's they are becoming so unreliable.
I've got bt fibre 500 and I have no issues with the bt home hub.
The deco's work for a bit then after a few days just stop, speed drops to 5mb/s. No matter what I do I cannot get the speed to be normal, reset them, reset the bt fibre modem etc...
Yet as soon as I plug the BT HH back in, bosh instant 500mb again. But plug the deco back in and 5mb.
After many hours or a day the deco's will just start to work.
Any suggestions?
TP-Link stuff is garbage. My son has the Deco mesh in his house and he’s always complaining.
I’ve just switched to Yayzi - £35 for 1GB on a 30 day rolling contract. They supplied me with Aginet TP-Link router. 450 mb in the front room and 46 mb through a plasterboard wall into the adjoining room - on a good day.
I switched over to my EERO 6 mesh systems and I’m getting 950mb front room and 700 mb in the room next door.
Flob
Just to balance, I have Deco mesh and its been good for the last 3 years. Only ever goes down when there's an issue BT side.
Have you run the diagnostic stuff in their app Andy or given support a call? How have you got it setup?
I have a primary unit which is wired to my router, then the other units mesh to this one, I keep the BT hub wifi turned off and just use the Deco mesh. Heard EERO are brilliant, if I was buying now I would buy them.
Andy_con
  clio 182
No I've not, I'll try it next time it happens
Ay Ay Ron
To echo Rob, we've had them for 6 months and not had an issue with it dropping speeds.
The only issue we've had is with the wireless printer, if we're in the living room trying to print in the bedroom we have to go there as I think that printer is connected to the bedroom deco?
Cub.
I’ve also had them coming up 6 months and they’ve been spot on.
Only one of them drops out occasionally and that’s because it is miles away from the other ones, so in essence I know I’m pushing my luck with it.
Andy_con
  clio 182
Mine goes bt fibre modem straight into deco.
The bt hh is not plugged in at all
Darryl_1983
  RB 182 Cup
I've had Deco Mesh for around 2 years now too, and I've not had any issues other than when my Virgin connection goes down. I get 500mb/s in every room in the house, whereas before with just the Virgin router, I'd be lucky to get double figures in my study.
Andy_con
  clio 182
With the bt hh plugged in I get 500mb, with the deco I get 250mb.
Whilst 250mb is fine for me, it's the always dropping rhats causing the issue.
Flob
So you have one unit plugged into your router? Thats the primary.
Can you plug a different unit into the router instead and give that a go, you might have a single unit with a fault? This might fix it.
The speed will always drop with a mesh/repeater setup
Andy_con
  clio 182
It goes bt fibre modem, wired directly into first deco, then I have a second deco wired into the first deco via a switch.
They came as a pack of three, so could dig the third out the loft and replace the main deco.
Flob
What model? If they are wired together they should be acting as hot spots not mesh, in my limited understanding a hotspot shouldn't drop/half speed. Wonder if you have a settings issue.
Id get the spare one out the loft and replace #1 to see if it changes things first.
Andy_con
  clio 182
Have ditched the deco's, they were just causing nothing but issues. Since going back to the bt hub I've not had a single issue.
The built in trouble shooter just says everything was working fine on the deco, am hoping someone is coming tonight to buy them.
Any recommendations on a mesh setup that works with bt fibre? I've got the smart hub 2, been looking at some of the bt disks, just wish they had more than one ethernet port on the back.
Flob
Have you looked at the TP-Link Decos mate, really good, nice setup tools too.
(Check out Google Next Wifi Pro and Amazon Eero - especially as its black Friday soon.... but if you set them up like its the 90's I won't be held responsible for the bad recommendation)
You could plug a little switch into the single ethernet output on the BT ones should you need.
Brigsy
  T.Turbo
Im using eero 6+ and seem to be ok up to now, no issues and speed levels always good. Doesnt make virgin media any better though!
DrR
  VW Golf GTD
I’ve got three X55s been using them just over a year now, no issues.
DrR
  VW Golf GTD
Correct me if I’m wrong but hotspot is wrong? What happens if you move from range of one deco to another it will drop the connection?
Flob
Yes hotspot is bad for a house, you want mesh. There are various setup options for the Decos which also means various opportunities to get it wrong. When you are out of range of a hotspot you drop connection. While mesh will just move onto the next node.
Ay Ay Ron
When I first set mine up it was automatically setup as a hotspot. When going to my son’s room it dropped and reconnected.
Now I’ve changed it to mesh I no longer have this issue. Still get s**t speeds in his room though compared to elsewhere. Maybe I’ll redo his deco when I’m back home.
  • Like
Reactions: DrR
The Psychedelic Socialist
We've got three EAP225s running in hotspot mode as each one is wired into the switch via PoE and we don't lose connection as we move from one to the other.
I thought the only difference between mesh and hotspot mode was that mesh uses wifi for the backhaul, while hotspots are hardwired in? Or am I just using the wrong terms nowadays?
Andy_con
  clio 182
what id settle for is a single unit that works with the bt smart hub 2 to create a mesh, but it must have at least 2 ethernet ports.
Andy_con
  clio 182
Originally was your workshop deco wired to your BT router or the other deco?
Other deco
It went white bt fibre modem into mian deco, then cables to a second deco in the workshop
When rhe decos worked they were great, just screwed up every other week
