Clio 172 - Track Car
Hi All,
Currently suffering with a P0120 fault in my 172.
At the pedal Connector Im measuring two 5v reference signals, two grounds, one wire 0-2.5v and another 0v.
Im guessing that the line I'm not getting a range of voltage is due to a short. Continuity is fine to the white plug in the loom but obviously that means very little for a 5v sensor signal.
Can anyone confirm the pinouts for the pedal so I know which wire I'm looking at? And any idea why I'm only seeing 2.5v max on the one pin,
Already changed the ecu part of the engine loom but not the fuse box to bulk head part so fairly certain the fault is with that.
Cheers!
Cheers!
