Track geometry settings
  PH1
Where can I find a guide to geometry settings for track, use its for a PH1?
I'm sure I found a site a few months ago that had some great info across the RS range but I'm buggered if I can find it again:dapprove:
ta
Col
  Lionel Richie
whatever suits you, there is no correct answer, every car i do is a bit different to the last as i have to set it up to what the customer wants
  Not a 320d
What would you reccomend for a fast road setup for a GT on coilovers?
-1.5deg of front camber, -1Deg rear camber, and the remaining settings from a clio 200?
  Evo 8 MR
What about toe?
Is it normal for fwd cars to have negative values on the front wheels?
  Lionel Richie
again, entiley upto the driver, i run (on my own car) the smallest amount of toe in, but the general concensus is toe out is the way to go, but i don't get on with it
