track rod end knocking
When will a defective track rod end tend to knock, ive got a knocking when pulling off, steering under acceleration and braking. Has had a new dogbone mount both wishbones and front springs and shocks replaced
Jack the car up and move the road wheel from the 9'oclock to 3'clock position, if theres movement its the tie rods, 12'clock to 6'clock movement would indicate bearings. If its knocking I would check your top mounts.
Check your CV joints. Unless you already have, I'm guessing since a lot has been changed under there already you've ruled them out.
