Track Tyres in Winter
cs_rich
I tried posting in the Focus ST forum but it's a bit of a ghost town compared to CS....
How sketchy is it running a daily on what are basically track tyres in the winter / wet?
My ST has P Zero Corsas fitted which seems to be in the same class as things like the Cup 2 (https://www.tyrereviews.com/Tyre-Tests/The-BEST-Track-Day-Tyres-for-2024.htm) albeit being a bit better in the wet and a bit worse in the dry.
But how terrible will it be in winter? I live in Norfolk so 'winter' really just means a bit wet and below 7°C and I haven't seen snow in years.
Will it be like running full-on ditchfinders, or just not quite as good as something like a PS4S at 10/10ths but perfectly adequate for the most part?
Ive ran semi slicks through winter years ago and they can be a bit loose in lower temps. You wont die if your driving steady.
They look pretty decent tbh
Good to hear. Would be nice if I can still push on though. My old Fiesta was still quick enough in winter though that had the benefit of PS5s.
Yeah, it's a reasonable tread pattern and the fact it scored highest in that tyre test in wet conditions gives me some hope they'll be decent.
Might all be academic though if I use them up at CSF and replace them with a set of PZ5s or PS4Ss in autumn.
You’re not going to be pushing on if it’s cold and wet, but if you’re not careless and don’t go smashing through standing water at 70mph you’ll live.
I wouldn’t call semislicks in winter an enjoyable experience.
Concur with the above. Poor water clearing and the temps really do make life difficult (as you can’t put enough energy into the rubber).
Obviously you’ll be fine, but you certainly won’t be pushing on.
Yeah, I know I'll never be able to push on in winter like I can in summer regardless of tyre choice.
I guess my question was really, how much worse is a track focused tyre like the Corsa compared to a decent summer tyre like the PS5 when it gets cold and wet. Night and day, or only really noticeable above 7/10ths?
If you want to drive quick on non dry days then change tyre for something suitable for lower temps. PS4S,PS5 or whatever, grip will be much better.
I found that some tyres don’t like the cold.
PS4S and Contisport 5 were not lethal in sub 8 degrees, but certainly took some serious effort to get temp into the tyre.
They were excellent in the rain though.
Drive for the winter conditions and not expecting a dry summers day grip and you will be fine.
I’m speaking from the terms of AD08R and R888R, Maxxsport RB5 etc but those tyres are night and day worse than a Pilot Sport 4/5 when it’s cold and wet. Hands down.
But what you have is more like a Cup 2 where it’s a bit like a semi slick but designed to still have some road manners in adverse conditions because OEs don’t want to fit full blown semislicks on a car that they’re going to sell to a customer who’s going to drive it out of the dealership mid winter.
That's a fair point. I keep forgetting I'm not driving a modified car any more and that the onus is on Ford (not me) to ensure the car is actually driveable as sold.
It's night and day the moment you get to a wet/cold/wet and cold roundabout and the car does nothing.
It's definitely noticeable at low speeds.
I ran the clio through winter with 651 sports on and as long as I drove like it was a 1.2 clio not an RS they didn't try to kill me.
The Michelin pilot super sport on the M2 (oe fitment) are w**k in anything under 10°c and the car behaved like a fiesta on maccies trays. Get some PS4/5 for winter.
Or just buy another set of winter wheels?
Cross climates on one set, track ready stuff on the other. Best of both worlds.
A second set of the 19s would be another £1,500 which is more than I'd want to spend really given CSF will probably be my only track day (and I really want to keep the OE look).
I think I'll just aim to get my money's worth from the Corsas this summer / CSF, then replace with PS4s, PZ5s or SC7s in late autumn.
You have not used man maths well, not at all.
I really like 2 sets of wheels because winter tyres are so good in cold weather but so s**t for the rest of the year and you end up averaging wear so summers feel like they last ages... also my summer wheels stayed mint and didn't get all horrid and corroded. You likely save money doing it and still have a set of wheels to sell at the end.
I would defo recommend fitting a good set of all weather's for winter, them p zeros are a summer tyre really.
I run goodyear vector 4s in winter and they are fine in the snow/rain, other tyre I run is the ps4s for summer, it's not the best in very cold weather imo
Hmmm, I am the persuadable type....
I'm assuming that something less track focused like a PS4S or PZ5 would still be better than the Corsas in the summer, in the wet.
If so, I'll probably junk the Corsas late this year, then see how I get on with the slightly less aggressive summers over winter. (East Anglian winters have been pretty lame of late)
In spring I'll probably be looking at Mountune M330 upgrade so then I can revisit the second set of wheels / winter tyres in autumn '26.
Have they accepted your application Porl?
I think it will make it there, I don't know if it will also make it back...
Is the BM too asbo?
I'm sure if the jag invades Germany it'll make it home again. Stick some union Jack's on it for good measure 🇬🇧
R888R are f**king hilarious in the wet. Would highly recommend a set in the winter if you want 29/10 danger levels.
Accelera 651's grip well in 3°C (albeit on a MINI Cooper S). For a track tyre they have plenty of rain channels and about 7mm depth so no real issues with standing water compared to slightly more serious track tyres like AR1's. Interestingly they're not too bad in the dry at colder temperatures but standing water is a no-no (experience on my 172).
I do plan on doing a damp (read: not moist moist) day on NS2R's at some point.
Apparently some of the Cup series guys use them as wets, the mentalists.
Just feels like a great way to almost die but also learn some car control
I lapped a pal of mine using ns2r’s on a wet Cadwell, on a set of bald 595rs’s 😂. They’re lethal
NS2Rs are shite in the dry never mind wet 😂
I've not got any other experience with a semi slick so I can't really comment much beyond I found them alright?
Slightly more grip in the dry, but they don't "go off" like a road tyre. Which, TBF, was exactly what I wanted
PS4S are quicker and last just as well, plus they are a million times better in the wet
But if you've not ran anything else I guess they will feel decent enough with their mad stuff sidewalls
