Traction control light on after fitting aftermarket steering wheel
Car  Phase 2 172
Just fitted my new aftermarket steering wheel. Obviously airbag and service lights are on as no airbag, but also my traction control light has come on and won't go away :S.
Any ideas??
I know this might sound really obvious, but have you made sure the ESP button by your right knee hasn't been pressed by accident?
Yeah I pressed it a few times and the light won't go off. Unless an abs sensor or something has popped out?
Isn't TCS and Cruise on the same Circuit, so removing Cruise switch on Wheel might set it off.
if you have a Tuner or Fault reader it'll tell you whats wrong.
This may have been covered in the search section a few times too,
Mmmmmmmmmmmm in that case I can only say get a fault reader on it, it'll pop up straight away what it is.
If you wheelspin the car what happens to the light out of curiosity?
Give it a go, it';; be fun ( off road of course ), if the light doesn't change and stays on the circuit is constantly open, all you should have to do then is find it and....................... well I'd say snip but probably blank off with a battery or something, similar job to airbag lights.
