translating rs tuner fault codes
  182
i have two fault codes my rs tuner is flagging up and im struggling to find out what they are.DF0129 inconsistency between track 1-2 pedal, DF0258 first sensor reference voltage.
could any one shed some lght on this please?
what might cause this fault?
thanks in advance
  182
i have no clue mate, for some reason im not getting hits on google etc. car is a 182FF incase it makes any difference.
ADS_V6
  172 cup clio v6 st
Had this,renault even put new throttle body on.Big white plug by fuses near battery was the cause if i remember corrosion on the pins
ADS_V6
  172 cup clio v6 st
Try search google with the limp mode,mine became scary suddenly no power randomly ,hope you sort it :up:
  182
yeah its a bit strange on the motorway with no power being stuck at 50 ish mph. ill update if i find something or need more ideas lol.
thank you
  172 Cup
I had it the other night df0129 (among others) was from water getting somewhere where it shouldnt have. Went a bit quick through some deep water and put it in safe mode. I checked all the electrical conections under the bonnet and gave them a good spray of wd40. In the morning it had cleared and was back to normal.
