Trohy suspension on the bay.
Da
Trader Rating - 100%
48   0   0
  Less
Springs are Eibach iirc so should be easy to obtain suitable replacement rear springs.
6   0   0
if fitting these to a 172 don't you need to change the hub to a 182 one? im sure i read somewhere there was a difference between the 172 and 182 hubs/suspension...or am i mistaken?
3   0   0
  tiTTy & SV650
The bolt spacing is different between 172 and 182, also the 182 / trophy has wider track than the 172 so you'd prob need 182 cup hubs and some camber bolts (or just turn the hole into a slot and use some shakeproof washers if you aint fussy lol)
