172 cup
will a set of trophy rear dampers fit onto a 182FF????????
cheers
Matty
cheers
Matty
Says in the op it's a cup-packed car.They will only fit if the 182 had the Cup packs. Will not fit the non-Cup 182s
FF= both cup packs.It does? :S
FF= both cup packs.
No, FF=not cup. You then specify whether you had styling/suspension packs.
he said cup 'packed'
not cup.
Non. Check with the FF pioneers.No, FF=not cup. You then specify whether you had styling/suspension packs.
