lol all this talk of clips and CLIPS confusing ay.
You will need the following. How you get them is up to you... you will need an airbag replacement resistor as even if your mate turns of the lights they will come straight back on again.
pretensioner socket and clip to connect the cables coming out of the pretensioner to the wiring loom.
airbag replacement resistor.
lower section has the wires that originally went into the seat airbag stripped and pushed into it.
the stripped wires that once went to the airbag go in the connector like this:
All these images came from
link so are ©red cup (user on here)
Its an excellent guide if you need some help although the wiring in the above image is explained wrongly (colours into holes but the image above thankfully is correct - so it must have been a typo)
