tuner list aux socket
Car  LY R27
firstly the stereo is from a megane but i believe its the same one
i have a 6 disc changer already installed and i dont want to get rid of this
anyway of keeping both the 6 cd changer and and have an aux cable
thanks
BROCKY
http://www.maplin.co.uk/Module.aspx?ModuleNo=23189&C=SO&U=strat15
I bougt the 3.5mm jack to aux from a chap on here, which gave the aux output connector an RCA connections. This means I could plug in anything with RCA connectors on the end. You could then use that switch box to effectively give you 2 inputs, you'd have to switch on that box between the two, I'm also assuming the CD changer is a boggo sound input with seperate power in which case you'd cut the sound cables and replace with RCA, if it's powered from the HU this probably wouldn't work.
ok so what your saying (if im correct)
is to basically connect a box where the cd changer would connect (but the box has 2 inputs) and connect one to the changer and the other to a jack socket?
sounds like it shouldnt be too hard
some pics and or more details would be brilliant
thank you :)
