Stevieh
You cant really "add" power lost by the charger. The net result is what is important.
Whats the spec of your engine?
Has the turbo been properly matched to it?
Have the camshafts been matched to this?
Im guessing not. Im guessing its a hit-and-hope conversion, which with turbochargers is always going to be more make or break. (this isnt a dig at you, more a reflection of reality when companies bolt random parts on and hope for the best).
With a s/c you dont have as large an issue with compressor mapping for c/r or cam profiles, and as said the na spec cams will be more suited to a sc application in general.
This cumulative error could easily be 50bhp.
I aggree, it would be nice to see some of the claimed figures for s/c kits verified, but I am no way suprised by the difference.
With a bit of research (turbine maps, compressor maps) on your GT28R you should be able to calculate your pressure ratio (exhaust to inlet) at different points in the rev range and see if you are likely to be seeing backflow
The effect is the same as running the car at roughly -15,000' below sea level.
just a thought,
you could get adjustable cam pulleys and tune out the valve overlap then run more boost.
i cant remember the exact figure but i recal something like for every 2-3deg C of inlet temp you'l lose 10% of power. as i say cant remember if those figures are 100% accurate but you get the idea!
other way around, 10C is worth about 3%, it's not quite that straightforward as the ECU may do strange things, but it's a ballpark figure.
