There is no space left behind the engine, and the turbo is touching the heatshield. Will the heatshield squash a bit? I only need a few mm for clearance.
From the looks of things you'll have to machine the flanges and the actuator bracket possibly to ensure clearance, the turbine housing itself isnt touching, just the actuator bracket.
I was thinking similar, undo the engine mounts, swing on the engine and re-tighten the bolts work?? Bearing in mind I haven't seen any 182 Turbos let alone worked on, so dunno.
