Turning over Non start 182 54 plate
Car  Silver182 and RB 182
Hope someone can help
just fitted another engine into 182 car turns over but won't start has fuel all original electrical bits of .....original car fitted tried different crank sensor..checked all connections ...still won't start
Has an alarm fitted with led in centre console.....immobiliser light on dash goes out on cranking.....
Any help would be great fully appreciated ...thanks in advance
cambelt had snapped .....on old engine
lock/unlock it on the plip first ;)
all earths connected? one above driveshaft on the box and the big earth strap under the passenger wheel arch
Thanks for replying
yes both earths are connected and done the unlockingand locking part ......is the centre console led supposed to be lit .as ..nothing happening there
Im lost now ....
Just checked 10.9v at injectors ..nothing at coil pack.....any advice be appreciated ty
Ty
Are you 100% sure the fuel pump is priming?
Check the replys in the engine bay fuel box right next to the battery. Make sure they aren't corroded. And make sure they are functional.
I've pulled all of them out......all seem ok.....noticed that throttle keeps buzzing after cranking until u unplug and plug back in
Also noticed after cranking filament warning in centre of dash is alight..says in book electronic malfunction don't know if this is related
Best of luck with this fella, I've got the exact same issue with the ph1 - checked relays, done continuity tests on the loom. Still no start. Tried relays and new sensors all round.
Called in to see mike @ rentech today...for advice ...
Great chap ....would highly recommend him to anyone , gave me lots of valuable advice
Ty mike
