Twitchy 172?
Car  PH2 172
Hi all, just after some advice really.
Recently my car has become very 'twitchy' when driving, with the steering feeling pretty shaky if i hit a cats eye or a bump in the road. It really does pull the car quite abit which is pretty unnerving, and it seems much worse in the wet.
Local Garage has looked at the tracking and its fine, and correct psi in the tyres.
any other ideas as to what could be causing this??
Oh also, the car does pull to the right slightly, would this suggest a shocks problem also?
And how would i check the shocks are ok? just look for leaks/fluid on the shocks?
hi mine did this when i first got it about a week ago and the ride was horid. so i orderd some coilovers and it turned out all bar one shock was f~~ked and made it jump all over the road .
