Tyre deflating
  Golf GTD Mk7
Noticed that my tyre was flat a few weeks ago. So pumped it up and noticed that it is continuing to go down veryyyyyyyyyyy slowly. The car is on the drive all week, so not driven loads. Took the tyre off and nothing to be seen i.e. nails etc. Any ideas?
  Nothing at the mo :(
i had the same thing
took it to a tyre garage and there was a small and i mean small nail in the tyre lettting out air very slowly>... £15 poudns later and its all sorted with a puncture kit
  Golf GTD Mk7
basically put it up to 33psi, then two weeks later it's down to 28. I though maybe dust in valve, or a broken valve.
yep mine was the same. like i said. i had a tiny nail in the tyre letting it down slowly. get it checked at the tyre garage sooner then later mate!!
steve32c
  200T
check the valve is screwed in tight use a small screwdriver or valve key if you have one.
  BG 182 FF
if the valve is ok, even though you av sed there is no nails in the tyre tec, I would put some tyre weld in aswell to be doubly sure
