put in what it says on the tyre itself, cos when they make the tyres they dont make thousands of different individual ones for every type of car.
a 1.2 clio should be 29psi front and 30psi rear if you are on your own mainly in the car.....but if you have a fully car 31psi front 32psi rear
what??
when i had my 1.2 i used to run 32 up front and 30 out back. now i have 33/31 on the 172.
The car manufacturers set a recommended psi, the tyre manufacturers just state a maximum value ie. "Do not inflate above 60psi".what??
sorry, but i thought recommended pressures were there on the tyre for a reason, they dont list hundreds of different pressures on each tyre for all the different cars they might get fitted to, do they?
Lol, geordie what are you on about????
The same tyre could be fitted to a rear wheel drive car weighing 2 tons, and a front wheel drive car weighing a ton... why would you do what it says on the tyre sidewall???
The answer is 32 front 30 rear fella. lol
