Uh oh, please help, pro lines problem!
  172 Phase II
I'm changing my standard springs for eibach's. Got one done now but I thought I'd turn the wheel to check if everything was okay.
So when I turned it the spring "jumped" out of its place!
It's seated correctly (when straight) but when I turn the wheel left or right the spring jumps out at the bottom.
What did I do wrong??
Edit: this is with the front end in the air, it's still on jack stands.
  172 Phase II
Hmh, stupid mistake in retrospect.. Got it all in the right order but I put the rubber thing on the other way round. Fixed it now!
Now I can't get the two bolts to come out on the other side! The side that I just did went fine with a few taps of the hammer.
I guess maybe give heating it up a try?
