un-even wear on fronts?
Car  e92 + E46 M3 + Cup
Hi all, The last few weekends i've been washing the clio i've noticed that my front tyre tread is getting low :dapprove: thing is though when i had a good look today i noticed that there is about 2mm on the outside edge & around 3-4mm on the inside, I'm guessing this could be a tracking problem? basically i bought some dynamique alloys & dropped it 35mm so cant see the reno original alloys being at fault & i dont go 80mph into every corner so i'm guessing the lowering springs have caused the drop? if so what sort of £££ am i looking at spending to sort it
Thanks,
James
yea sounds like tracking and possibly camber at fault. Start with a wheel alignment check and adjust (£20 -£30)
You should've had the car tracked after it was lowered mate.
You live & you learn... :( ... will look into getting it track'd with in the next week, thanks for the quick replys guys
Any one know what i would be looking at for a pair of the 15" conti's that come as standard on the mk2?
Anyone know the best place to get ur tracking done?? im hopin to get myne lowered in the next week and want to get the tracking sorted just incase.
